68EFIvert
I have been driving my Mustang as a DD for the last week as some body work was done on my normal DD. I went to the the Post Office yesterday to drop off the paperwork for a Passport and the car would not start. When I turned on the key the fuel pump would not even come on. I waited a few minutes and the pump would turn on but did not have enough juice to crank. I figured that it was my battery but was not sure.
I called AAA and they came over to give me a jump. It took a few attempts but it finally turned over and started right up. I drove the car home and put on my battery charger. It seemed to charge fine and the charger turned off automatically.
Fast forward to this morning. My DD won't be done until this afternoon so I figure with a freshly charged battery I should be good to go. When I start driving down the road I kept a close eye on the volt gauge. It was running about 1.5 volts while driving under 2500 rpm but when I reached over 2500 then the volts jumped to 14. I turned my car around and went back home and decided to carpool with the wife today.
When I got back to the garage I hooked up my battery charger which is also an alternator and battery checker back up. The battery was showing 85% and the alternator was only putting out 75% of what a stock alternator should. My alternator is a 130 amp 3g unit so it should have been showing about 150% of a stock alternator. I purhcased a new alternator today from Summit and will see how it goes.
