RagTop
Old Grumpy
My 69 vert and my son's 69 SportsRoof both have the non-tach dash. The ammeter on both cars is relatively useless. I'm used to more modern cars that actually show a move on the meter when you turn on the headlights and will wiggle slightly when the turn signals flash. As far as I know neither of these 69 ammeters has moved in the last 16 years. Do any of these gauges actually work, or is mine working but I can't see it because it's just too fast? I've never opened up the dash on any car, but I'm strongly considering it on the vert. I may want to treat myself to one of those Original Ford Tooling dash pads and I am assuming that I will gain access to the back of the dash when I do that. Thought I'd slap in a new voltage regulator and have a look at the ammeter while I'm there. BTW, I know there is a Phillips screw in the center of the pad at the windshield base and I'm assuming that the four screws under the dash at the instrument panel and glove box cove are also retaining the pad. Are there many other screws retaining the pad that I should know about before I break out the pry bar?
