sigtauenus
I have a 30 year old house, lived here coming up on 6 years.
I just replaced a light fixture in the hallway that kept blowing bulbs with a new fixture that has a compact flourescent bulb. Its actually remarkably bright for only having 1 23 watt bulb.
Anyhow, when I turn off the light at the switch, the bulb flashes.
Weird, huh?
Well, I pulled everything apart again and found 55V on the circuit with the switches off (two 3-way switches), and basically figured out that I have connection somewhere in the circuit that is shorted neutral to ground. I checked multiple places and I have 55V on the voltmeter between neutral and ground. Not good.
Apparently the flourescent bulb is getting enough voltage to try to start but not enough to run, which explains the flashing light. Well, right now its disconnected again.
So, as if I don't have enough projects already, I'll be chasing down an outlet somewhere in the bedrooms that some worker bee wired incorrectly 30 years ago.
Sometimes working on this house I think it would easier to just gut everything back to the studs and start over.
Weird, huh?
