Sluggo
I'm converting my 69 Mustang to 3G using PA Performance's regulator upgrade.
I've attached a picture of my setup. My situation is a little unique because I'm also eliminating the solenoid in favor of a relay. I am running a mini-starter. Because the solenoid is eliminated I'm using a power lug to make the connections that would go there.
The orange wire coming from the old alternator harness is the one I believe the instructions say to cut and tape to the harness. The large black from the same connector goes to the ammeter. (factory gauge car) The small black is a ground that was grounded to the regulator chassis from the alternator chassis.
The large black has power to it key on or off. Since the other side of the ammeter is already hooked up to the power lug, I'm thinking that the large black can go to the lug on the battery or the alt side of the maxi fuse and possibly retain some ammeter function.
My wire colors on the regulator don't match the wiring diagram but I've confirmed that they are pinned correctly.
If you don't mind, have a look at the picture and see if it makes sense.
