I had another friendly little electical fire. Before, I lost a fuse in the flexalite E-fan circuit. I checked for faults and replaced it. Then, I lost another fuse, this time to a small fire, (see prior post). I replaced the fuse holder and the wire with a higher rated fuse. Today, I noticed that my E-fan did not come on even though the temp was in the range it was set for. I opened the hood and heard a snapping, bacon frying kind of noise coming from the fan controller and a symphony of buzzing and smoke from the motor. I pulled the wiring loose and it was very hot. I dont know if the PC board in the controller failed and fried the motor, or if the motor failed and fried the controller, or if some wiring issue fried them both. I could spend the time to figure out what caused the issues, but I am not that patient. The PO put all of this in, and the wiring seemed sloppy. I ordered a new fan and controller and I am going to rewire this all the way back to the source, relays and all. I know I can either wire it to a constant 12v source so that it will cool the radiator to the set point after the key is off. I can also connect it to an ignition switched 12v so that it only runs when the thermostat in the controller hits the set point with the key on. The instructions do not seem to make a recommendation one way or another. Which way should I go, ignition switched or non-switched? I know that I will wire it to he a/c compressor relay so that the fan activate regardless of coolant temp unless someone thinks that this is a bad idea for some reason.
I will post pics of the install once I finish. I hate electical fires, even small ones.
