I dug into my T5 to change my speedo gear, it needed a 23 tooth last year to calibrate properly but it ate that driven gear in no time flat, so I am going to go down to a 6 tooth drive gear I guess.
My big concern is I have a grind into 5th gear so I figured I would have a look.
I found this spring just sitting here, I am thinking that may have something to do with the grind into 5th gear?
I was just going to see if I could pop it back into place, but then I found this laying in there.
So I took the shift fork off, that pin did not want to budge, it took some work, but I got it out of the way and removed what I believe to be the 5th gear synchro assembly and found that the synchro blocking ring had some chew marks on it and the other two inserts were gone, I figure those inserts rolled around just enough to chew that ring up? I did find them at the bottom of the box when I took the top off and they look ok.
This looks kinda chewed up and I am guessing that its damaged from floating around unchecked. From what I know the trans has low miles and works perfectly except for that grind into 5th.
Here is the gear dogs/teeth. They are slightly chewed but I think I may try them again.
So my question is do you think I could just buy a new brass blocking ring and reassemble without major issue? Who sells these rings for the 5th gear, I dont want to buy a rebuild kit just for that one part.
Thanks.
Thanks.
