A
Anonymous
Guest
Looking to keep things simple on the AWD attempt. I have heard that you can eliminate the electronic control part of the 4R70 transmission if you swap the internals with an AOD? Anyone have any factual info on this? If not, I am set up to use the EEC 4 if necessary using the factory settings. Also, is there a piggyback add on tuner for the EEC that will control the shift points? What brand and where?
