Jonk67
Hey all, trying to make some progress. Started running the Lokar AOD TV cable I have last night:
KD2AODHT
and the carb spring bracket to see what needs to be done:
SRK-4000
Apparently the AOD cable is cut to fit as this thing is 6' long and I only need 3' it appears (looped around VC in pics below). Whats the best way to cut SS sheathing? wrap with tape and cut with sharp hacksaw?
Next up is the carb bracket does not look like it is going to be useful at all. Since I'm using the stock throttle setup, fabbed a rod and will not be using lokar's throttle cable this thing is in the way of the throttle rod. I see I could bend some 45* bends into a longer rod but then I'd question the chance the rod will flex/bend at some point. I will probably put a 45 at the firewall end just to line up straight with the carb. linkage but don't see 2 sets (basically a bow in the rod) to get around the lokar bracket.
My thoughts are to just fab my own 90* bracket coming off the 2 intake mount points I have instead of the carb base. It really only needs 2 holes, one to secure the TV end and one to hook the return springs to. Thoughts?
Throttle rod sitting on top of the carb spring/TV cable bracket in both pics:
I can get some better pics with daylight as I noticed the flash made everything shiny, I can also get a top down showing the 2 intake mounts I plan to use on the Stealth.
Jon
KD2AODHT
SRK-4000
Jon
