AOD with Fast Xfi
soc123_au
New Member
Just wondering if anyone is running Fast Xfi & an AOD. I am having trouble setting up the throttle & the TV cable. Has anyone found a solution?
This may not be exactly what you are looking for but I'm running a constant pressure valve body I purchased from SilverFox. I still run a Lokar cable to a carb to control shift points but I don't have to worry about burning the trans up because of a poorly adjueted cable.
I have considered adding Silver fox's constant pressure to my aod next time I change the fluid. Could you give me an idea of what they cost? I've got about 8000 miles on my aod (built by me) and it works great. I'm adding the efi stuff very soon and considering this. I'm getting rid of the carb and intake and this would be a good time for it. I've been using the lokar cables for the tv adjustment and had no problems with setting the pressure with an oil pressure gauge. Just thinking about going differently like you did. Thanks, Gary.
Have you tried a gauge and set the pressure? Nice looking car BTW.
