Aussie67
Are you in Victoria or NSW? The rego label on the commodore looks like it's Victorian?
Wash your mouth out. We are in Gods country on the Sunshine Coast in Queensland. Both cars have personalised plates.Are you in Victoria or NSW? The rego label on the commodore looks like it's Victorian?
Thanks guys. One day I might even get it looking as good as yours. Think I might have to change the starter solenoid as it seems to be running on a bit and not disengaging immediately after the engine starts. Its not bad, but is annoying.
Not sure if its the solenoid or the clapper starter.
Without digging back into what motor you are running I am guessing it is the bendix on the starter hanging up, not the solenoid.
Oh, those solenoids are known to arc closed it's rather common. Rap 'em with a wrench when it's messing up and 9 times outta 10 they'll release. I've kept one in damn near every Ford I've ever owned. Have one stashed in the current car now.I have never heard of a Ford fender mounted solenoid to hang, but it is a common problem with the bendix. But if it was mine I would replace the solenoid first just because it’s cheap and easy. Even though it’s probably not the issue, it is easy to eliminate it as the problem. Then I would tackle the starter.
Why not upgrade to a pmgr starter? Smaller, faster, better, easier to get, probably lasts longer.
I know you can use the fox body starters. Just have to make sure itll work with your trans. I had one on the T5/302 I had in my coupe.
