"cmayna" said:David,
Though I have now done two Autometer installs in both Red and Shag, I've used Painless wiring. I can't see too many issues except that in most cases with the Autometer gauges there are 3 posts in the back (Sending, Ground & power). Each gauge is fed with 12volts so you would not use the stock voltage reducer.
In addition each gauge has it's own light whereas the stock gauges do not have their own light but some crappy light bulb nearby. So connecting the stock light wiring to each gauge is one obstacle.
I think hooking up the signal wires shouldn't be too much of a problem unless you might be introducing a gauge to your bezel which you didn't have before.
Grounding each gauge shouldn't be a big issue.
Power to each gauge might be a challenge. Run a major wire off the ignition switch and branch off it to feed each gauge.
I believe you run a fuse between the ignition switch and the power wires.
Maybe Midlife will chime and and set me straight for I'm just quickly trying to remember what I've had to do before without too much thought.
Craig
