coupster
I pulled the axles to exchange the third member. This rear has been in the car for about 9 months. No problems with it, just changing the gear ratio with another pumpkin that is set up with 3.0o gears. The bearings on the axles were really stuck in the axle tube, but after alot of banging w/ slide hammer, the axles came out. The bearings had alot of rust around them, causing them to be stuck in there really well. When I spin the bearings, the spin quite a bit, and sound "dry" when they spin. Do I need to change these and the seals? I didn't have any noise coming from the rear prior to pulling it apart. I don't want to spend $ if not needed, but then again, I am here and have them out. What does everyone think?
