carefact0rzero
New Member
so i'm pulling the axles to get new bearings pressed on. the pass. side came out nice and easy, but the driver side isn't budging. i flipped the brake drum over and tried using that to pull it, and even took that off and tried to use the wheel, i figured the weight behind that would slide that freakin' axle out. but no luck. anybody have some suggestions on getting that thing out? i read about using a slide hammer but that's pretty much the same thing i was doing with the drum/ wheel...
