JBauer4363
Been getting my car back together to go in to get my front end alignment check but after sitting for the last 6 months it was running rough. When I give it any gas it boggs down and backfires. Adjusted the idle screws w/vac. gauge, checked/adjusted timing and idle, left the shaker off and started to drive it and wow several backfires w/big flames on minor accel. Didnt get a block. I am certainly not very good at this stuff but I had it running good last fall (I just dont remember how). Heres the specs:
351C Holley 600 4bb
Auto
Mild cam
Timing 10 to 12deg. btdc-have used both runs about the same. Even tried 6 deg like service manual says still hesitated.
Pertronix 2 - Flamethrower coil.
Idle 950 to 980
Vac 16Lbs bounces between 15-16 at idle. If i rev it up it vac goes up and doesnt bounce around at all.
Idle screws 1 1/2 turns out (turning 1/2 turn more either way doesnt seem to affect vac.)
anything about these numbers look off? What would cause a hesitation/backfire like mentioned? Gonna tackle it again Sunday but if anyone has any tips I would be appreciated. Thanks
JBauer4363
351C Holley 600 4bb
Auto
Mild cam
Idle 950 to 980
JBauer4363
