The car is a 69 with 302. Engine is internaly stock. Headers, C4, 4brl. original dist converted to Ignitor pointless.
About 2 months ago was having flooding issues with original 2brl. Changed to Holley 4brl (600, vac second, elec choke) and a dual plane intake. The car ran GREAT except for developing an oil leak. This was eventualy traced to a blown rear seal. During the oil leak investigation I repulled the intake in the event the gaskets were leaking there. While I had the distrib out I cleaned it with break cleaner, being careful to only clean the outside(hopefuly).
The next day going into work the thing began backfireing and could just keep 50mph. No power and backfireing like crazy. I checked the dist when I got it home and it looked fine. The vacume and mechanical advance were working.
I pulled the engine to replace the rear main and discovered the timing gear on the cam was SHOT. Guessed it had jumped. Reassembled the engine and it started and idled great. Took it around the block, very easy to insure all was well. Then tried a litle harder accelleration from a stop and BACKFIRE. So I checked the dist, timing, wires, etc. Can not see anything out of place.
The dist is original, but converted to igniter pointless. New cap and rotor, new wires, new plugs. Idles great. Prior to the backfireing it ran very strong and getting 17+mpg.
I'm stuck. It sounds like an ignition issue. I made sure the timming marks on new timming chain set were correct. Top one at 6 and bottom at 12.
