1965Mustang
To make an extremely long story short. I need someone to tell me who to talk to for help. I have posted several times and got a lot of help. Got my engine build finished in May. Ran great. Took it to Roush Racing for a tune. It is a 93, efi, 302 with several upgrades. Went to get it from Roush and the water hose had blown and torn up my brand new hood I just had painted. It can be fixed. Drove the car home and it would not start the next day. Finally found the adapter between the TPS and painless harness was missing. Fixed that. It would not idle consistently. Took it back to Roush. They said it was fixed. Went less than 1/2 mile and it was idling at 2500 rpm. Took it back. They were lost. Said to bring it back. Never did since I had no confidence in them. The head of the dyno room called someone else for advice. Took it to a friend who restores cars. He went back through all the wiring (Painless), changed IAC, changed to stock computer, and ran diagnostics. Never could get to idle consitently. Still between 1800 and 2500. Read the forums and found Pro Dyno in Rock Hill, SC to be one of the best. It has been there for 6 weeks now. Changed computers again, IAC, and TPS. Added FPA headers and Magnaflow 2 1/2 exhaust and retuned. Pulled over 300 rwhp, 330 torque and they told me to come and get it. I drove it around the block and it ran great. Was going to get gas across the street and it went crazy again. Then it woiuld not start until I bled the fuel rail. It is still there and they are lost. Only suggestion is to start changing parts which are all new. It is now grounded to the frame=twice, battery, and body twice so it is not the ground. It could be coincidence but I have not been able to drive it anywhere since I took it to Roush in May. Pro Dyno is supposed to be the best and they are baffled. Only way they could get it to idle correctly was to disconnect IAC. I need help. I am totally disgusted. If you need to talk, PM me and I will give you all my personal contact info. Thanks for any help. I am out of options.
