This is sort of a dorky question, but here goes!  I used a specialty Harmonic Balancer on the '90 5.0 HO (not using the serpentine setup).  It is not as thick as the original type balancer so I need to add a spacer to take up the difference so that I can torque down the balancer bolt to the required amount.  (if I did this now, the pulleys would not be lined up at all)  I've been driving around with it probably at 1/2 the correct amount.  I did, however, use some blue locktite when I put it on.  It's time I correct this...so does the spacer go between the Balancer and the timing cover?  Do I torque down the balancer and bolt as it should be and then measure for the correct spacer?  Then of course remove the balancer and put the spacer between it and the timing cover to "take up the slack"?  Appreciate any wisdom on this issue.
