AtlantaSteve
Ok, battery in the trunk, here we go again.
I'm trying to decide if I want to put the battery in the trunk or not. Here is what I have decided:
1) I'm going to have a Ford 130A/3G Alternator
2) PMGR Mini-Starter
3) Absolutely will have a solenoid in the trunk.
So what does the wiring look like for this? The PMGR starters usually have a constant hot from the battery, but this is not suggested, as you don't particularly want a constant hot going down the length of your car...Since I won't have a constant hot on the starter solenoid, I can't tap that for the constant hot lines inside the car(Headlights, horn, etc), so it sounds like I still need to run a (fuse protected) line, parallel to the start hot. Will I need a third line for the alternator, or can I use this constant hot? I'm thinking of installing a distribution block where the battery currently is, and using that as the constant hot and connection point for the alternator? Is that OK to do? Seems like that'd need to be a pretty big wire, maybe 6 or 8 gauge?
Finally, how do I wire up the solenoid+starter? I had heard that the starter power needs to be hot BEFORE The key is triggered, to prevent damage to the starter. If the Solenoid has cut power to the starter, and is triggered on by the signal from the ignition switch, then power will actually reach the trigger on the starter BEFORE the battery power hits it. (Because of the closing time of the solenoid in the trunk)
You'll find attached a wiring diagram I mocked up, but it suffers from this problem I described above. ANy guidance would be appreciated.
EDIT TO ADD: There should also be a fuse on the line that goes from the battery to the distribution block...forgot to add that in.
