I'm trying to gather all the parts to move the battery to the back and eliminate the fender starter solenoid... have a mini-starter with a built-in solenoid. Here is what is planned so far:
- 14' welding 1-gauge cable positive (thicker copper wire)
- 3' welding 1-gauge cable negative ground
- fuse block spliced into the 1-gauge positive cable for future high amperage accessories
- disconnect switch w/ alternator protection - http://www.pegasusautoracing.com/productdetails1.asp?RecID=1464 - need to call for the amperage rating.
- battery tray - http://www.summitracing.com/parts/AFC-50302
What should I add/remove/replace/avoid? I know some just added a power distribution block under the dash to avoid all the wires going to the solenoid underneath car. Right now, I'm trying to find the right fuse block instead...
