Belt configuration
So when my cars done and back together I plan to run just power steering, no A/C. My current setup on the car is a serpentine system but I cant run that setup unless i relocate the location of the power steering pump when i remove the A/C. Should I stick with a serpentine setup or go to a 2 belt system?
If you change from the serpentine, you most likely will have to change the water pump to the opposite rotation plus all the pulleys and maybe the harmonic balancer. Research the change before you jump in. It is really a matter of what look you want....old school or modded....I have had both and see no issues either way.
