I had never received my specs with my crate motor. It arrived in a crate, It looked great and the video showed the break in but no paper work. I had been in good contact with the builder company and knew eventually I would get around to asking for some specs, besides I know nothing about what these numbers mean.
So out of interest here ya go , maybe you can tell me your opinion.
302
Block Bored :.030 oversized with deck plate
Crank Casting: Nodular cast oil holes deburred and polished
Connecting Rods:Scat Steel beam w/ARP Retaining bolts 3.25 stroke
Pistons:Speed Pro H273CP Pistons Rings: Perfect circle chrome Moly
Rod bearings:Federal Mogul Tri-metal Bearings standard
Cam Bearings: Same as above
Cam Shaft:Hyd. Roller 212/222 Dur@.50 .498/.512 lift Elgin E1017P
Valve Intake: 1.94 Stainless
Valve Exhaust: 1.6 Stainless
Valve Adjustment: ZERO LASH plus additional 180 degrees
Valve Springs:1.45 inch diameter heavy duty matching cam shaft
Intake:EDL.Dual Plane7121
Head Cast: EDL.Aluminum Perf. RPM cylinder heads 60cc heads
Lifters:Hydraulic Roller HT-2205 Lifters
Rockers: Comp Cams Magnum Roller Rockers 1.6 to 1 Ratio 1442-16
Push Rods: Pro Form 66423c Chrome Moly Hardened
Fly Wheel 157 tooth 50 oz.
Balancer 50 oz.
302
Balancer 50 oz.
