Robs66Coupe
Hey guys. I'm doing some work on the firewall and toeboards now for my '66 coupe. Right now, the floors are out (pretty bad rust all around), the engine is removed, and the toeboard and part of the firewall are removed. The problem I have is that I can't really get into the area that I need to in order to fit and replace the firewall piece. I was thinking, since I'll need to repair the cowl anyway, if I remove the cowl now, that will give me access to the area I need. My question is, with the floors and cowl out, will the jackstands under the frame and the roof be enough to keep the car from shifting too much or should I make some braces and bolt them on somewhere. Then, if I need braces, where should they go? Thanks guys.
