So School me on Mustang brakes please.
I installed the CSRP kit today, but have some issues. It's his SAWP.1 kit
All the major stuff went in fine, and Iam able to bleed at all 4 wheels, but Iam not getting any braking, and I think because I went off his instructions a litte with my line lock, I may of done something wrong??
One thing I found out when I called him is that I might have a built in residual pressure valed in my MC, he was right, so I removed it. I think I should also reverse the large, and small reservoir, and use the large for the front discs. But I should still get some breaking? Here is my set up:
1. Small reservoir of MC > line lock > T-Fitting> front brakes > (line lock not wired yet)
2. Big reservoir of MC > Adjustable Proportioning Valve > residual pressure valve. > T-Fitting to rear brakes
3. Bench Bleed the MC works fine.
4. Removed OEM Brass Distributions block, and use my own T - fitting on front and rear.
Hummm? :shrug
Hummm? :shrug
