Dennis66stang
I just installed a Painless wire harness in my 66 Mustang. The headlight switch is new as well as the Turn signal switch.
When I powered everything up last night for the first time I had a few Issues that I need to look into.
I havent had time to look start tracking down any of the problems but here is what I ran into.
When I step on the brakes, they come on but the instrument lights come on as well.
When I turn the headlights switch on, the tail lights seem to be lighting up bright like the brake lights, when I step on the brakes there is no change in brightness.
When I turn on the turn signal (either direction) both rear turn signals come on together, the fronts work correctly. Also with the headlights off, the turn signals also make the instrument lights come on.
I think my problem is the turn signal switch. Its been a while since I replaced it and I am wondering if I put some wires in the wrong spots. Does anyone have a diagram of the pin locations for that connector? I looked at the wiring diagrams and its hard to tell which wire goes to which pin.
Anything else I should check? Could the headlight switch be bad or wired wrong as well?
Also I have LED Sequential taillights if that makes a difference. Is it possible for those to be wired incorrectly?
Thanks for any help
Dennis
Thanks for any help
Dennis
