One_fast67
I am getting close to the point of putting my car back together and I am looking for advice on what t do with my brake lines. Car was originally a non-power, 4 wheel drum brake car. I am converting to manual 4 wheel discs. In addition to this, I am going with an aftermarket dual reservoir master cylinder with an aftermarket proportioning valve. If I understand it correctly, this setup would eliminate the factory distribution block and would require modification of factory brake lines. Can this be confirmed? Since the original lines were in rough shape, I was already planning on replacing all of them. Would it make more sense to just make my own lines instead of getting replacement lines and then having to modify them for my application? If I go this route, does anyone know how much bulk line I would need to do the entire car? If I wanted to add an “idiot light” to my dash for my new setup, how would I do that if the factory distribution block is no longer part of the system?
