Brake Master Cylinder
Triton
On this type of Ford brake master cylinder which port is for the front brakes?
Thanks
Same as stock, rear line mounts in front, front line in back. What are you using this on? It has a pretty big bore.
Whats pretty big ?
I know it is the bore seize they mean but could you explaine it .
And what are the seizes for manual and for power brakes ?
I have 1970 front brakes and a Versailles rear brakes, but i an using a fox body booster so that I can get the hydraulic clutch mounted next to it. Needed the larger bore for better pedal feel!
