Can I get these to work?
Ok, was fortunate to run across this find....twin fan pack off a late model Ford Escape. Now, I'm curious if I can get these to work on my '67 notchback. I'll scour the boards for tips on electricals, but all tips are welcome. I measured my current radiator and it's 21" wide. Each of these fans is 14" diameter. How wide is a big block radiator? I would love to swap out the flex fan and free up some power.
Thanks - Jeff
Ok, so the fans aren't exactly the same...one is 5 bladed and the other is 6 bladed. I separated them and think I'll try to use the 6 blade fan. There's a black wire and a red wire coming out from it and I have the female lead that goes to it. Can anyone recommend a single fan switch setup? I think I can rig up some angle aluminum to attach this to my radiator. May even try to make an aluminum shroud, too. I think I'll try one fan on my car, as it's a small block, 5.0 and I don't want to have to spend the money on a big block radiator just to use a twin fan setup. My current small block radiator and flex fan have not had too much issue keeping the car cool. It helps that I don't have a/c, but my build likely doesn't need the capacity of a big block radiator.
Thanks.
