i done 3 things adjusted floats they were too high,set the mixture also my acc pump diaphram need adjusted after all that car runs fine."Mr. Din" said:im having kind of the same issues. did you get your issue fixed?
this vid will give a basic insight on how floats work"hamburgler" said:Hey GT350,im an absolute newb when it comes to carbs and still a beginner when it comes to stangs so can you explain in detail how i could go about doing the same things you did to ur carb?I have a holly double pumper(4150).Although mine also tends to stall when cold if i dont continuously rev it.Thx
how did you get on with your car?"hamburgler" said:Those ARE pretty good but this carb video is absolutely great for newbs.
http://v8tvshow.com/content/view/110/28/
Hopefully after watching them all ill be able to set my carb properly.Thx GT350
