Now that the car is back on the road, its time to fine tune some things. I'm having problems getting the motor to react when I mash the pedal quickly from a stop. It basically falls flat on its arse for a few seconds and then kicks into gear. The motor seems responsive by flipping the throttle open quickly while parked in the garage working under the hood.
Motor specs are a fairly stock 351w with stock heads and bottom end, Comp XE262H cam, dual plane intake, Holley 670cfm street avenger, Duraspark Dizzy and box, T56 manual trans. I have good vacuum and I'm running 35
