So we redid my '68 and took it out for the first highway drive back to my house from my uncle's shop. It was idling kinda rough and had trouble running when in gear. We adjusted the idle up some and that helped a little. It's idling now at around 1100 in park and around 900 in gear. The motor is a 347 stroker with an auto tranny BTW. So I drove it about 12 miles on the highway and turned on to the backroad to go home. I kicked it in the butt and it totally lost power, almost completely died even. I let off the gas and it came out of it. Tried it again with the same result. Well I slowly got it back up to highway speed until I had to stop at the stop sign. Once I got to the stop sign, the car died and would not restart. We waited a couple minutes and it finally popped over but sputtered like it was flooded and died. We got it to the side of the road and waited for a few more minutes. Finally got it started, but it really acted like it was flooded. Got to my house and it was having a hard time staying running when in gear. I tried starting it about an hour later, and it started, but it didn't "pop off" like a new engine should. What the heck is wrong? The motor was tested when it was built and ran fine. I was driving it around town without any problems. Edelbrock said to check fuel pressure to make sure it's not too high, otherwise send the carb in. There are no noticeable vacuum leaks. The only thing we did to the engine was take the carb off to put the engine in and put it back on. The carb is a Edelbrock thunder series 650 with electric choke.
Thanks, Justin
Thanks, Justin
