Carb Spacer or not
Johnny M
I want to know what you guy think about carb spacers.
A 1" spacer came with my motor and the studs on my intake are longer to accommodate a carb spacer but after some web research there seems to be mixed opinions on them.
As long as I have the clearance should I run with it?
Carb spacers are almost always a win in terms of power improvement. The biggest gain comes from getting the carb up and isolated from the heat of the manifold.
"Johnny M" said:
Thats decided then....
Going to run one as long as i have the clearance.
You don't have to run a full 1" spacer if clearance is an issue. The most important thing is that the spacer is phenolic.
If it didn't cost an arm and leg, I'd send you the 1/2" phenolic spacer hanging on my garage wall.
There are lots of advantages to using a spacer. A phenolic spacer helps with heat transfer from the intake to the carb. A spacer helps increase plenum volume and helps fine tune a combination. The best spacers that I have seen are 4-hole tappered spacers like the Wilson spacers and Super Sucker spacers. It is no joke that you can pick up 10+ hp with them and sometimes much more. They arent cheap though at $100+.
I had a problem with hesitation when starting from a stop light, a normal start, with a Holley 570 avenger on my 302/5sp. I got stuck in traffic and the temp jumped up to 195+ and the hesitation seemed to go away. I took out the 1/2 inch phenolic spacer and the problem is gone. Of course I could have some other problem being masked like I really need a bigger squirter.
I have a PA address........
i will defo try the 1"spacer and see how i get on...still a long way off actually runnnig the motor but will be checking clearance pretty soon.
Thanks for all the info..
Johnny
The first problem I'd address is the improper thermostat. If you're 'jumping' to 195F, the engine is running too cold. Ideal operating temp for a sbf is 195-210F. There's a reason the factory put 192/195 thermostats in them.
Hi, I'm using a 1" phenolic spacer with a 600 edelbrock carb on a weiand intake atop a '90 5.0 HO with the AOD tranny and I never have a problem with "Hot" start that some seems to have with carbs.
