Carpet Installation
You got very good advice from those guys here.!!
That thing with the velcro sounds very good to hold things in place!!!
Think twice , cut once !!!! ( no your fingers !! ) :roll :roll
I would install the kick panels first prior the seats.
Works better.
Seats last.IMHO
"gtscode" said:
How much carpet goes under the kick panels?
Should I put the seats then the sill plates?
The holes on the vertical portion of the sill plates are very hard to get to if the seats are in place.
"Daves69Coupe" said:
did you use any type of adhesive or no?
Nope between seatbelts, scuff plate, kick panels, seats, shifter bezel, high beam switch it's pretty secure.
damn works for me then. I know I had seen someone use glue or some type of spray on a car building show before so I wasnt sure if it is needed. Thanks for the answers gtscode
