OK...my extended warranty is up, and it's time to change the oil. Put the 06 up on the lift after loosening up the lug nuts for tire rotation. Put a socket and wrench on the oil pan plug and nothing happens! Well, it did slip off prying with a good deal of force. WTF?
Find a 6 point 5/8" socket and a breaker bar, and it felt like about 80-100 ft-pounds to break the nut loose. Huh? Last oil change was done at a Stealership. Shop Manual says 19 ft-lbs, and after removing the oil, I tighten up the nut. Put in oil, and not a drop leaks out. I don't understand why anyone would gorilla an oil pan plug.
Surprisingly, I did not find a metal or plastic washer under the plug; maybe the new designed plug doesn't need one.
