I am rewiring my car and running a 3g alt. Can I run a wire from the alt. to the relays for the fan and headlights, then another wire from the alt. for the main power feed to the fuse block, then the same wire back to the trunk to a 175 amp little fuse then to the battery? Or do I have to run a dedicated single wire for the charge wire and then another wire back to the fuse block and relays?
Thanks
Thanks
