After 30 years off the road,(catastrophe blown engine) I recently completed the rebuild and install of my 351C in my 1970 Mach 1. The problem is I can't install the clutch equalizer bar to the engine side from the frame side or from the frame side to the engine side. There does not seem to be enough room (< 3/4 in) between the engine the end of the equalizer bar. I have jacked up the engine off the mounts, moved the engine toward the passenger side as far as possible to gain more room, but to no avail. I don't want to disconnect the engine from tranny bellhousing again,(doing this alone took me 4 days to  connect) but (will if I have to) and start over again. Don't want to go hydraulic, or cable. (No budget for this area) Need a short cut if there is one. Need help. After 35 years I just want to drive this thing before Christmas 2013. Thanks for any help.
