Shaun
This kit enables you to install SN95 Cobra ('94-'04) rear rotors and calipers onto your 8" or 9" small, big or Torino (late model - Currie etc.) bearing rear end.
Kit Features:
Visit our site for more info! - www.streetortrack.com Mention this add when purchasing both front and rear brackets for either DRUM or DISK spindles and we'll ship BOTH FREE!
Don't know what rear end you have? Measure your axle end flange using the dimensions below:
Kit Features:
- CAD designed, CNC milled custom 6061-T6 aluminum brackets. These lightweight but extremely strong billet brackets weigh just 14oz's per side. Finished with a black hard anodize plating. Bearing removal not required for installation!
- Custom made aluminum hub-centric adapter shims take up the gap between the axle end snout and rotor hub hole. This makes the rotor truly hub-centric.
- All mounting hardware.
