will a 1" drop 620lb/in coil spring from MU work with a 1.75" UCA drop?? if not, what would you recommend? TIA
http://mustangunlimited.com/itemdy00.asp?T1=C305+01
"hivewax" said:i was just thinking that with so much drop of the UCA and a short coil spring, the coil spring can be jarred loose while driving and cause some damage.
EDIT: does that sound retarded?! :doh
