Comp 1.6 Roller Tip Rockers SBF (Non-Rail)
65fast
I have a set of Comp Magnum Roller Rockers Arms (P/N 1442-16) that I no longer need.
I used these on a 302 for about ~5K miles until my cam pin broke which lead to bent valves. I replaced the cylinder heads that were damaged and got a set of full roller rocker arms with the new heads which is why I did not reuse these.
As you can see in the picture most of the tips have marks similar to the individual one I have pictured. The marks are not below the surface and the tips are just as smooth when they were new. I am not sure what caused the marks, but below is a link to a question I asked regarding this. This includes all 16 lock nuts and pivot balls. I can take more pictures if interested.
The rockers arms should only be used on cylinder heads with pushrod guideplates or the early 289 heads with the slotted pushrod holes.
http://forums.vintage-mustang.com/vintage-mustang-forum/571420-roller-tip-wear-pic.html
Looking to get $100 + Shipping.
Thanks!
