This might be Cleveland sensitive being a 4 bolter. Don't know.
For a power steering setup without AC, is the crank 4 bolt pulley, a 2 groover with the two grooves next to each other? I have seen some on ebay which the larger groove is around 8" diameter and smaller groove is infact right behind it and is around 6-3/4" dia.
I found the following one [in pic] in my boxes of parts. The larger groove is 6-5/8" diameter and the smaller one is 5-7/8". Total Width is approx 2-1/4". What the heck is this pulley for? Hmmmmm....Alt and smog only?
Regarding water pump pulley, what is the typical diameter and is it a 2 groover?
The water pump pulley I have is 6 1/2" diameter, which would be too big if I used a 8" crank pulley. They'd hit each other.
Thanks
Thanks
