Jonk67
Hi all, long story short, local shop built my 333 stroker and degreed the cam the first time but the cam gear dowl pin had to come out. months after I picked up the engine. They reinstalled the timing gears (not sure if they had to remove cam, doubt they'd remember now months later).
I marked the cam/crank gear with a (black) marker for where they were lined up when first built/degreed, now it appears that when they reinstalled they didn't degree it again and simply lined the standard dots (white) up on the gears. I don't want to leave it like this and leave power on the table from the degreed settings. Can I simply rotate it to get them to line up or do I need to remove the gears/chain, rotate and reinstall the gears/chain with the black marks lined up? I don't want to haul it back to them again as it was a miscommunication for the first fix and they didn't charge me anything to fix the roll pin.
Jon
![IMG_0938.jpg](http://i194.photobucket.com/albums/z192/jkoed/1967%20Mustang%20Coupe/Engine/IMG_0938.jpg)
![IMG_0945.jpg](http://i194.photobucket.com/albums/z192/jkoed/1967%20Mustang%20Coupe/Engine/IMG_0945.jpg)
![IMG_0942.jpg](http://i194.photobucket.com/albums/z192/jkoed/1967%20Mustang%20Coupe/Engine/IMG_0942.jpg)
Jon
