Neglected68
I am trying to figure out if I have a misfire with my car. I have the Summit 600 cfm carb with a Weiand Stealth manifold and dual exhaust (no crossover pipe), but otherwise a stock 289. I hear what seems like a regular miss from the exhaust pipe on the passenger side, though the engine seems to be pulling well. When I was trying to isolate the possibly misfiring cylinder, I noticed that when I pull the spark plug wires from the distributor cap one at a time (following the firing order), only every other one causes the engine rpm to drop. Is this normal? :shrug I have put in new spark plugs and the wires seem to be in good shape. I haven't replaced the points, but the gap is correct. Could this be a timing issue? The timing is set at 6-7 degrees, but the vacuum advance is almost touching the top radiator hose. Could I have put the distributor in off by one tooth?
Thanks!
Thanks!
