Mustang_Charly
I love it when I actually find out why some part has failed...
I am in the process of rebuilding my 8 inch differential. First time, never done that before, but hey, I bought the "how to" video, (thanks Ken, at Badshoe Productions) so why not?
I always have had a loud "clunk" when shifting manually from first to second (C4 automatic) at low load; suspected bad u-joints. Upon closer inspection, the u-joints looked and felt fine. However, I did notice that the diff had a lot of backlash at the pinion input, so I figured I would be rebuilding it soon.
Then, this summer I put in new leaf springs, and in the process of moving the rear axle housing around and putting it up on blocks to clean it off, of course it swung around nose down once in a while, as they tend to do, being nose heavy and all.
Soon after putting it all back together I began to notice a "rattling" noise coming from the rear, but only in "float" conditions. I put up with it through the fall, and firmed up my plans for the rebuild once the snow started falling.
Well, now I am in the middle of it (both snowfall and rebuild) and found the problem:The pinion pilot bearing was completely empty; no rollers at all. The bearing had fallen apart at some time in the far past, all of the rollers falling out of the race. Then I have to assume when the axle housing dropped nose down during the leaf spring change, some of the rollers found a new location inside the diff. After reinstalling and driving, they then proceeded to do their damage to the pinion gear. Photos attached:
Overview:
Close up of pilot bearing:
"Empty" pilot bearing race:
Broken pinion gear tooth:
Stuff I found in the bottom of the axle housing:
Overview:
