Ponyman66
Yak, yak, yak
Just thought I'd pass this bit of info along to help out anyone doing a 5.0 swap into their car. Most folks doing, or contemplating this swap, know you need to move the dipstick location from the side of the block into the timing chain cover in order to match the front sump pan. The solution I've found that most folks are doing in order to plug the block hole is driving a wooden dowel into the hole. I'm not trying to insult those who've taken this route, after all it is quick, easy and super cheap. This solution just never sat too well with me when it came to doing my block though. I believe part of the reasoning for people using a piece of wood has been due to difficulty in locating a suitable metal plug (basically, a very small diameter freeze plug).
To save everyone from the frustration of trying to find a proper plug, here's the info:
3/8" diameter plug, NAPA p/n 3812185, cost- 0.72 each! It taps in snug just like it was meant to be there!
Now, no more reasons to jam a stick in the hole! :yah
