Neglected68
A while back, I posted a question about what appears to be an aftermarket distributor control valve on my 68:
http://www.stangfix.com/testforum2/inde ... #msg112755
I am trying to determine how best to remove the thing. I know that there was a wire to the valve from the + side of the coil. The other wire from the valve leads to a flat 3 wire connector that goes into the firewall above the accelerator pedal (the connector closest to the master cylinder in the picture below.) The wire from the valve is in the middle, with the wire from the temperature sensor on one side and a wire from the + side of the coil on the other. When I crawl under the dash, I can't tell where the wires go. Does anyone have an idea where the valve may be wired to? To further complicate things, I suspect that this connector was supposed to have the oil pressure gauge wire. This gauge is now wired by a single wire that passes through the firewall in the hole for the speedo cable.
Would it be safe to just unplug the wire from the valve to the connector? I am worried that I might cause a short or some other electrical problem.
TIA
TIA
