SELLERSRODSHOP
thought i would post this up if anyone else wanted to build something a little bit sturdier than the cast, hollow, made in taiwan lowering blocks on the market. i started by doing a little shopping in the cutoff bin @ metal supermarket & found a length of 2.5"x2" solid aluminum stock long enough to make 2 pair (i need to drop the 36 p/u rear too). cut the stock to the length of the mounting pads on the rear, in my case 4.75", mark the center of the block, chuck it up in the drill press & drill a 1/4" pilot hole completely thru the block.
on one side, using the 1/4" hole as a pilot, drill approx. 1/2" deep with a 9/16" bit. this will be the centering hole that fits over the pin in the leaf spring.
flip it over & drill the other side approx 1.25" deep with a 15/32" bit. (like my high dollar depth guage??)
next thread the 15/32" hole with a 9/16"x12TPI tap.
find a couple 9/16"x12 x2" long bolts. any length will be fine as long as it has an unthreaded section under the head. thread the bolt as far as it will go & mark it taking nota as to how many threads are between the block & unthreaded section. this is how much you need to shorten the threaded end of the bolt.
cut the excess length off the end & reinstall into the block & tighten down.
now simply cut the head off the bolt & bevel the edge leaving approx 3/8" of the unthreaded portion of the bolt as the alignment pin for the rear end pad.
these are much sturdier than the hollow ones & after lowering, if i need to change the pinion angle of the rear, i can simply chuck them up in the mill & machine to the desired angle which eliminates the need for additional shims. to further strengthen things up, i had the new u bolts made from 1/2" stock, which is heavier than the original 7/16" bolts, so i'll have to mill out the holes a little in the bottom shock mount plate.
the whole project took only an hour to complete & with the high grade of aluminum, i have the option of ball milling the sides & polishing them up for a "show car" appearance. i probably wont do this on the mustang, but will on the 36. (i'll post pics of those when they are finished)
