sigtauenus
I finally figured out the vacuum leak I had was with the 1" spacer with PCV. I removed the spacer and set the carb directly on the intake (with a gasket of course), but that meant running the PCV to a port on the back of the intake on the runner to #7.
Intake is a C9OX, carb is a Holley 4150.
I have a miss in one of the cylinders. I will try to confirm tonight which cylinder it is and will get back to you, but since I just did this change-a-roo with the PCV, I'm suspecting that as the culprit until I figure out otherwise.
