tarafied1
I swapped out the broken vent/wing window on my friends 67 today and now the door won't latch. All the linkage is still hooked up and moving. Any ideas what is wrong?
"sigtauenus" said:Could this be a problem with the spring that holds tension on the latch? I've had a couple go bad on my fastback over the years and had the same problem as you describe. They are 6 bucks new from NPD, and are not something you want to scavenge used.
