drill bit size spot weld cutter
GT350
Does anyone know what drill bit size spot weld cutter is for removing spot welds on mustang floor supports?
I got my spot weld cutter from Eastwood years ago and it works GREAT ! A 3/8 drill bit will work but you lose the metal in the second layer of sheet metal. The cutter is well worth getting (get extra cutter heads too just in case you dull the first one).
