So I'm told I need to get the June COTM back on the road........ :steer
I need to run new fuel lines for the 5.0 EFI engine.
I need some help. I was going to run 5/16 steel lines for both return and feed lines.
Picked a Ron Morris fuel sending unit and realized the feed line is 3/8.
The fuel pump I bought 2 years ago is 5/16 inlet and outlet.
Is 5/16 too small for a feed line?
Also should I run the fuel filter before or after the pump?
I was thinking I could find an adapter to reduce the outlet to 5/16 hose before the fuel pump and go 5/16 from there to fuel rails?
Any suggestions would be appreciated. Plumbing is not my strong point.
