AzPete
So, according to the electric fan companies, the most popular temp. sensor switch turns the fan on a 185* and off at 175*.
I really wonder what the "off" side of it is for. If one has a 180* thermostat in the engine, the water should never get below 180* in the block or in the thermostat housing where most mount the sensor. Even if the sensor is mounted in the radiator, the actual temp would most likely never get to 175* either.
As for the "on" temp....again, why? If the fan runs from the first start of the car, it would be no different than a regular fan. What is so great about turning it on at a temp. that is higher than thermostat? Saving a power surge during the initial start up of the car?
Has anyone actually had the fan shut off as you are cruising on the highway where companies say you do not need a fan?
Just wondering on the entire logic of having a fan with an on and off option.....
